Tractor Talk Discussion Forum
Broken Rod on my Tecumseh Rototiller
jjaj2022
05-22-2006 20:02:21
Hey guys, great forum here. Do you know where I can get an oil slinger online for my tiller? I lost my rod yesterday and the oil slinger went with it. The model # is HH60, Thanks!
[IMG]http://i2.photobucket.com/albums/y42/RIPMacDre/m005.jpg[/IMG]
buickanddeere
05-23-2006 07:22:33
 penny wise pound poor Re: Broken Rod on my Tecumse in reply to jjaj2022, 05-22-2006 20:02:21
You can rebuild it if you want but..... ..... ..... I learned the hard way a couple of times it's cheaper and certainly less agrivation to toss a trashed engine in the scrap pile. And start over with all new everything with a warrenty. Outlets such as www.smallenginewarehouse.com etc sell brand new engines at a deep discount.
supergrumpy
05-23-2006 07:05:44
 Re: Broken Rod on my Tecumseh Rototiller in reply to jjaj2022, 05-22-2006 20:02:21
that engine tends to break connecting rods but usually happens after oil gets low and/or very dirty
you will likely find aluminum welded to the journal, I use 600 grit wet/dry paper to remove it but will try the muriatic acid trick on my next one
I try to get all the metal flakes out too
unclemerle
05-23-2006 05:04:27
JJ
Where are you located? I have an extra engine located in SWMN I took off my troy built tiller this spring. Engine is excellent carb is shot.
Merle
jjaj2022
05-28-2006 13:41:51
 Re: Broken Rod on my Tecumseh Rototiller in reply to unclemerle, 05-23-2006 05:04:27
Thanks but it might be a but far to drive. I'm in California. :)
hlc
05-23-2006 04:38:03
With the same crank it may throw another rod soon.
UncleTom
05-23-2006 02:47:00
Was it working hard when it went or it just said it had enough. I have seen a lot of the rods give up for no reason.
jjaj2022
05-28-2006 13:44:16
 Re: Broken Rod on my Tecumseh Rototiller in reply to UncleTom, 05-23-2006 02:47:00
It wasn't working at all. I fired it up to move it and it just died after a few feet. I pulled the rope and it was just free spinning.
jjaj2022
05-22-2006 20:36:46
I found it! Thanks guys! I found out it's actually a governor gear or something like that, lol. All I know is I need another one. Glad it's only 8 bucks!
http://search.cartserver.com/search/search.cgi?cartid=a-8671&category=Tecumseh_Parts&maxhits=20&keywords=30591&go=GO%21
jjaj2022
05-22-2006 20:05:48
third party image
Here's a pic of the slinger.
