Tractor Talk Discussion Forum
Belarus 205AS hydraulic lift
Nickc205
05-22-2006 19:25:57
I have just recently purchased a belarus 250AS and know little to nothing about tractors. The Hydraulic lift was working fine and then after a day of using it, it won't pick up anymore... we thought it was low on oil (i do know it takes HD30 motor oil) and we put nearly 3/4 of a 2 gallon bottle in the reservior... but it still won't pick up. If you hold up on the lever and pick up on the bushhog with several people, it will go up and stay up after you let go of lever, and it will also drop when you push down lever... Any ideas as to what could be causing the problem?
CR
05-23-2006 09:25:05
 Re: Belarus 205AS hydraulic lift in reply to Nickc205, 05-22-2006 19:25:57
Nick,
The 250AS I run has two hydraulic levers. The lever on the left (closest to your leg) raises and lowers implements. The right hand lever is for the remote hydraulics. Make sure that the remote hydraulic lever is in the centered position. IIRC if it is pushed forward or if it is pulled back it will not operate the three point correctly.
HTH
CR
Herb McIntyre
05-22-2006 20:07:04
By chance is there a lever to the right of the drivers seat? Pull the lever all the way back and lock it in place. At least that works with a 400. Just thought I'd take a guess
:-)FORDBOY(-:
05-22-2006 20:06:32
We had the same problem with ours and it was low but we put what is called hy-trans fluid in it i picked it up at wally world its in a blue bottle.... I would doulbe check to see what fluid it takes and ill check to make sure im not up in the night if needed we have a service manual too. If you know of anything you would like out of it i can email some scans to you! Hope this helps -Tyler
Dan-IA
05-23-2006 11:51:47
 Re: Belarus 205AS hydraulic lift in reply to :-)FORDBOY(-:, 05-22-2006 20:06:32
Hy-Trans from Wally World. That could be half your problem. Nothing against Wally World, but the Hy-Trans from my International dealer pours like honey. The stuff from Wally World pours like water.
I'd say there's a difference.
