Tractor Talk Discussion Forum
Injector pump problems????
Josh in PA
05-22-2006 08:11:31
I have an Oliver 1655 with Roosa master pump. This spring it would start and run well, but after a while loose power till it couldnt even move itself. If you shut it off, waited a few minutes and started it again, it would run well for a while. A neighbor told me to take the ball and spring out of the check valve on the return line, as this was likely clogging with pieces of a plastic ring in the pump that was coming apart. I did this and it ran well for awhile, but yesterday mowing hay i had trouble again. It would occasionally rev up or down a few hundred rpm on its own, and it lost power once. I noticed when it lost power it was smoking a lot. I shut it down a few minutes, started it back up and it ran well the rest of the day. Is it time for an injector pump rebuild? Thanks for any help,
Josh
Thick fuel teacher
05-23-2006 05:26:51
 Re: Injector pump problems???? in reply to Josh in PA, 05-22-2006 08:11:31
This is a example of the ease of gas moters. Thick fuel moters are great if you are farming full time, but for small and part timers like myself you cant beat a $30 carb kit, and they allways seem to be off the shelf at napa. Last inj pump I bought for a 756 had to send way out to the hinderlands of the west to get. Sorry for your problems, a good inj shop should fix you up ED
AB
05-22-2006 19:39:42
Have you drained/cleaned the fuel tank, cleaned the sediment bowel, and replaced the fuel filters? You may have clogged filters and/or some water in your fuel.
msb
05-22-2006 11:53:05
For all you guys who advocate breaking the ball out of the return line fitting,it has a purpose and that purpose is to keep a bit of housing pressure on the pump to aid in expelling air from the pump housing plus it helps stabilize the governor action.Yes, it is a short time fix,but if it were not important Roosa Master would not have spent the extra money on the check valve fitting.Think about it.Only delaying the inevitible pump overhaul can be quite expensive sometimes.If the rivets wear off like I have seen before the result is not pretty.They can lock up the governor weights and the operator will lose control of the engine speed.
VADAVE
05-22-2006 08:39:12
YES!!!
Removing the ball and spring is only intented to be a temporary fix to get the immediate job finished.
Larry from md
05-22-2006 08:31:39
At this point it could still be things outside the pump causeing your problems.If you don't see coffieground size chuncks comeing out of the pump don't do a rebuild.
Josh in PA
05-22-2006 08:46:51
 Re: Injector pump problems???? in reply to Larry from md, 05-22-2006 08:31:39
Thats the thing I wondered about, he said I would find the valve clogged up with pieces of the plastic ring. I never found any peices at all.
Josh
the tractor vet
05-22-2006 08:23:27
Yep she is on her last legs and one of these times it could vary well go wide open and not able to shut down till the pices and parts start flyen. Now if your in western Pa. then run it over to Harry at Progressive diesel and he will fix ya wright up.
Josh in PA
05-22-2006 08:57:33
 Re: Injector pump problems???? in reply to the tractor vet, 05-22-2006 08:23:27
I'm a small farmer and this is my first diesel tractor. Should I replace the injectors when the pump is rebuilt, or just rebuild the pump?
Josh
the tractor vet
05-22-2006 09:29:27
 Re: Injector pump problems???? in reply to Josh in PA, 05-22-2006 08:57:33
Well it would be wise to have the injectors tested for breaking pressure and spary pattern and then repair or replace as needed.
