Tractor Talk Discussion Forum
hitch issue
farmallbee
05-21-2006 16:52:01
trying to place a hitch on 96 minivan. It bolts in under the frame. The problem is 3 of the 4 bolts stripped out.-the nut that is welded inside of the channel frame came loose. Only solution I can see is cutting a small hole in frame and removing bolt that way then replace nut manually when I put the hitch on-any other suggestions?
Mark - IN.
05-21-2006 22:13:34
 Re: hitch issue in reply to farmallbee, 05-21-2006 16:52:01
Oops, sorry, thought I read caravan. Sorry. Regardless, if the gas tank is anywhere near there, no torch.
Mark
Mark - IN.
05-21-2006 22:12:02
Well, like anything else, your way would be one way to do it, by drilling and using nuts, bolts, and washers. Another way would be to drill into the head and shaft and try an easyout bit, but it"d be a big help to soak plenty of some sort of penetrating oil on the other bolt side ahead of time. I don"t know anything about a Dodge Caravan, specifically where the gas tank is located, but if you"re nowhere near it, you could try heating the nuts to get them to expand away from the bolt threads to help loosen them up first. However, if your gas tank is anywhere near there, nix that idea.
3 out of 4 stripped? Whom did that? Not you, I"m sure.
Mark
