Tractor Talk Discussion Forum
pistons
jd jd
05-19-2006 17:48:39
anyone know how hot a piston will get?...what temp.....will jb weld hold under piston by the rispin????? ????? ????? ????? ??
Ken L
05-20-2006 05:35:37
 Re: pistons in reply to jd jd, 05-19-2006 17:48:39
Many years ago when I was still in high school, (35 years ago) I bought an 18-28 Oliver Hart-Parr. When I pulled it apart, all the pistons had one crack in them from the bottom of the skirt going up towards the pin. They were between 1 inch to 11/2 inch long. An old time mechanic told me to drill a small hole in the end of the crack and then braze the hole and the crack, file it smooth and put it back together. For a few years, that tractor got used a lot. Now just a few times a year. I have not had a problem yet but, one of these years, I'm going to take it apart just to check if there are anymore cracks.
RAB
05-19-2006 21:52:20
I"m with buickanddeere!! - you must be kidding!!
RAB
buickanddeere
05-19-2006 20:47:00
Your kidding..... ..... right?
old art
05-19-2006 19:14:10
if you have a cracked piston it best to replace if it fails as you are running it is sure to do much dammage. you have it out now easy too replace only 1 tare down no extra time loss when you realy need it. old art
old
05-19-2006 18:46:47
One word. NOPE
