Tractor Talk Discussion Forum
wd45 not hooking up
champ40
05-18-2006 19:40:49
we currently pull two wd45's one at 4000lb and the other at 4500lb class. we have tons of power but can't get them to hook up on the track. drawbar height has to be at 17" per rules of the pull. drawbar can be in or out. any secrets on adjusting the drawbar to get these wd45's to hook up? is out better than in?
IaGary
05-18-2006 20:26:58
 Re: wd45 not hooking up in reply to champ40, 05-18-2006 19:40:49
If you can run 38" tires that will get you better traction.
Those little 28" tires always were the downfall of the AC traction.
Now you hook to the snap coupler hitch on that AC and it will pull.
Friend ran 38" tires on a D17 and it made a huge difference.
Gary
BushogPapa
05-18-2006 19:44:19
Short is always best, I think you need to work on weight balance and tire pressure.. You can't keep the front down with a long drawbar...
