Tractor Talk Discussion Forum
shaft bolts for brush hog slip clutch
leeinmass
05-10-2006 16:57:09
Got a 5 foot wide brush hog behind a Case 430 with a slip clutch on the pto driveline. Should I use Grade 2 bolts on either end of the slip clutch or something stronger?
Thanks, Lee
Sam#3
05-10-2006 20:12:39
 Re: shaft bolts for brush hog slip clutch in reply to leeinmass, 05-10-2006 16:57:09
Is the slip clutch on a smooth shaft of splined?
If it's splined it really doesn't matter. The bolt is there to prevent the shaft from pulling apart.
leeinmass
05-11-2006 05:22:27
 Re: shaft bolts for brush hog slip clutch in reply to Sam#3, 05-10-2006 20:12:39
The slip clutch is smooth x smooth.
Russ from MN
05-10-2006 18:58:07
I would recommend grade 2 only, if the slip clutch ever gets rained on it can rust up and not slip, then you need a shear bolt to save your equipment.
