Tractor Talk Discussion Forum
1945 H FARMALL`
CARL PATTON
05-06-2006 19:46:45
WAS TRYING TO GET TRACTOR TO RUN BETTER. WAS MESSING WITH THE TIMING. GOT IT SO FAR OUT OF TIME THAT IT WILL NOT EVEN START NOW. WHAT STEPS DO I NEED TO TAKE TO GET THE MAGNITO IN TIME WITH THE MOTOR? DESPERATE. PLEASE HELP.
Dave_Id
05-07-2006 07:55:24
 Re: 1945 H FARMALL` in reply to CARL PATTON, 05-06-2006 19:46:45
Loosed the mag and push against block. Put finger in number one plug hole. Slowly crank until compression pushes finger out of hole. Continue to crank until timing mark lines up. Now slowly pull mag toward you until the impulse thingie clicks. Tighten mag. You should be timed correctly.
Nebraska Cowman
05-07-2006 03:25:57
It's prety simple realy. Spark needs to take place just as piston comes over center on compression stroke. If you messed up the tiny gears inside the mag their are marks on them. Firing order is 1342 clockwise looing at the mag cap.
third party image
Even bad boys are just as good as they can be
