Tractor Talk Discussion Forum
1970 IH 656 Hydro Steering Inoperative
Kirk Puttmann
05-03-2006 10:56:14
I have a 1970 international 656 Hydrostatic drive utility tractor. I am having no luck figuring out why my power steering won"t
work. Just quit all of a sudden last fall when I was using it. Was not cold yet, changed filter anyway. All other hydraulics work fine. I have had the whole system apart. Pump looked excellent, no filings or abnormal wear that I could see. Replaced pressure relief valve in flow divider. Inspected hand pump (below steering wheel) twice and everything looked great. Rebuilt steering cylinder. Checked check valve in junction block, okay. Checked control (pilot valve), spool valve looked good, moves freely; recirculating check ball and plug
looked good. I did find that the check valve seat in the pilot valve was blown out and I replaced it and the check valve. Replaced all
o-rings and reassembled to specs. I filled the system with Hy-Tran and ran it, still nothing. Will not even steer manually. Does not matter if front wheels are off the ground or not. Should I overfill the reservoir to try and prime the pump? Is there something I am overlooking. I have been struggling with this tractor for 3 months. With a line off of the steering cylinder, the hand pump pushes some fluid out when I turn the wheel in that direction, it is bubbly though. I am scraping for answers. Any help would be appreciated. Thanks and God Bless.
Sincerely,
Kirk M. Puttmann
Steve from Arkansas
05-03-2006 14:29:31
 Re: 1970 IH 656 Hydro Steering Inoperative in reply to Kirk Puttmann, 05-03-2006 10:56:14
I have a 1066 with simular problems. I dont know if they are anywhere the same system but a dealer tells me its the pump. I have to park mine lightly down hill, especially if fluid level is a little low. If it don't steer, take a line off the cylinder, use a can or something to catch the fluid, with tractor running turn the steering wheel round and around fast in one direction till pump is primed it will blow quite a lot of fluid out in a hurry so be prepared to shut it off and reconnect the line to the cylinder. I sure need to get mine fixed.
