Tractor Talk Discussion Forum
OT-asking for gearbox opinion
Iowa Leonard
05-02-2006 19:32:53
Who makes an affordable 1:1 ratio PTO right angle drive rated about 30-40hp? Your comment would be appreciated. Thanks
Iowa Leonard
05-03-2006 04:13:53
 Thank you in reply to Iowa Leonard, 05-02-2006 19:32:53
I appreciate the suggestions, I should find something out of these.
Bob
05-02-2006 19:55:07
 Re: OT-asking for gearbox opinion in reply to Iowa Leonard, 05-02-2006 19:32:53
Will any of these work for you?
Gene Davis (Ga.)
05-02-2006 19:49:29
Three examples come to mind. Years ago when I worked in my father"s JD dealership shop the old pull type combines sometimes were equipped a pto set up in place of a power unit,and it was a right angle box. The 9N,2N,8N Ford tractors had a right angle gearbox that actually was a belt pulley on the other end. The last one was some of the older pull type rotary mowers,Woods for example had a right angle gearbox to run the blade belts. Al of these will probably in the junk or fence row if still around now. Gene Davis
Joe(TX)
05-04-2006 05:25:48
 Re: OT-asking for gearbox opinion in reply to Gene Davis (Ga.), 05-02-2006 19:49:29
The Ford belt pulley boxes are not 1:1 rstio. A gearbox of of mower conditioner or round baler could work, but they are also not normally 1:1. Nost are around 2:1.
