Tractor Talk Discussion Forum
Spark Plug Sizes
doorman
04-29-2006 20:39:59
Can anyone tell me what the thread "pitch" is on a 7/8" spark plug? I have a Wisconsin V4 engine with 18 mm. sparkplugs that have stripped out holes. I may try to tap the holes for a 7/8" plug. Anyone ever try this? Thanks in advance doorman.
Coloken
04-30-2006 00:06:17
 Re: Spark Plug Sizes in reply to doorman, 04-29-2006 20:39:59
Years ago I did one...think it was the same as a pipe thread. Remember, pipe taps are tapered.
Bob
04-30-2006 01:03:18
 Re: Spark Plug Sizes in reply to Coloken, 04-30-2006 00:06:17
Ken,
The 7/8" thread he is asking about is 18tpi, stright thread.
Spark plugs are also made in 1/2" and 3/4" pipe thread (tapered), but that's not what he asked about.
coloken
04-30-2006 07:07:17
 Re: Spark Plug Sizes in reply to Bob, 04-30-2006 01:03:18
Thanks Bob, been a long time. Wasn't the model T Ford a pipe thread?
Bob
04-29-2006 22:38:38
7/8 -18tpi is the 7/8" spark plug standard.
Heli-Coils or thread-inserts cost only a couple of bucks per hole, and then you can use the recommended spark plug.
Here is ONE source for the 18MM inserts:
Mark - IN.
04-29-2006 20:53:07
Take the head to an engine machine shop. Let them do it in a controlled environment where they can block/lock it in place for machining. You can probably do it by hand with a lot of care, but if you mess up, it'll be more messed up and even closer to being scrap than it already might be. I wouldn't put any faith in helicoils under compression, although I've heard that it's been done. I'll bet not for long though.
Mark
