Tractor Talk Discussion Forum
Three point lift speed question
River Bottom Fa
04-25-2006 15:19:18
Built three point hitch last year for 39H.Used twin 2 1/2 inch cylinders on it.Nice hitch works good but lifts too fast to grade dirt or gravel with.Can I use a flow reducer of some sort without hurting the lift all pump? And does TSC sell a flow reducer..... Thanks River Bottom Farmer
JerryAR
04-25-2006 22:47:59
 Re: Three point lift speed question in reply to River Bottom Farmer, 04-25-2006 15:19:18
You can use a reducing orifice. They can be made like a washer with a small hole or there are fittings, usually in the swivel type that will slow the fluid down. Either one will work. TSC has the swivel type fitting with the built in reducer.
Bob
04-25-2006 21:52:30
Swap in larger cylinders. Thus will slow the lift speed without making the hydraulic system bypass.
CK from Ontario, Canada
04-25-2006 19:08:12
River Bottom Farmer, I am considering making a 3pth for a Case 440 I have that was purchased with no hitch. Does your system have draft sensing? If it does what did you use to accomplish that?
Glen in TX
04-25-2006 16:30:35
A green H or a red one? On a green H there is a flow control adjusting valve on bottom of hydraulic pump box to adjust flow. I don't know on a red one but would think you could use a flow control valve of some sort as long as you don't close it off all the way. Can also get flow restrictors for cylinders.
River Bottom Farmer
04-25-2006 16:40:19
 Re: Three point lift speed question/sorry Glen in reply to Glen in TX, 04-25-2006 16:30:35
Glen Its a 39 Farmall H I know you can get flow restrictors/reducers and flow control valves but I have heard how finicky the lift all pumps are about being deadheaded agains the relief valve just onder if resticting the flow would cause similar problems
Glen in TX
04-25-2006 21:45:12
 Re: Three point lift speed question/sorry Glen in reply to River Bottom Farmer, 04-25-2006 16:40:19
I reread your post and you said it lifts too fast. So if too fast with new style cylinders too it must have more pressure and flow than I was thinking it would have but wonder how much flow? Maybe a variable flow valve with a built in or adjustable relief valve? Lots of hydraulic stuff online at surpluscenter.com
