Tractor Talk Discussion Forum
16 hp Wisconsin
R FINK
04-23-2006 19:44:20
have a 16 hp single cylinder WISC engine in a old Yazoo mower. mowing this after noon and stoped running lost compresson and slowly wound down, no knock no bang. now can turn it over with no resistance. removed sparkplug and see a valve operating the mag turns and has spark. just wondering what happened , and wether its worth tearing it down. [have too many projects the way it is] thanks
jerrycpp
04-25-2006 15:48:52
 Re: 16 hp Wisconsin in reply to R FINK, 04-23-2006 19:44:20
If it is a stuck valve, use Marvel Mystery Oil in the fuel AND the oil once you get it running again. Keep in mind Wisconsin is a top of the line engine - parts are expensive, but the engine is just about bullet proof.
Leroy
04-24-2006 05:54:29
You were at work with it when it stoped so it has value to you or you would not have been using it so yes it is worth trying to fix
shannon from ohio
04-23-2006 20:02:01
Remove head and see if exhaust valve stuck open? I've see alot of the Kohler's do the same thing. Remove the valve and clean the stem thoroughly of all deposits
old
04-23-2006 19:47:51
I've seen rods brake in that way. No noise just it stop running
