Tractor Talk Discussion Forum
Oliver 60 thermostat troubles
old
04-22-2006 13:14:16
Well I picked up a thermostat for this Oliver 60 engine but it will not fit. The parts store book says its the same as for the 70, 77, 88 etc but it just plain will not fit. Do any of you have the correct part number for the thermostat for an Oliver 60?? If I can get the number or a few numbers then I might be able to cross the number to one I can buy locally.
Thanks
BEK
04-22-2006 18:50:46
 Re: Oliver 60 thermostat troubles in reply to old, 04-22-2006 13:14:16
I bought one for my 77 at NAPA a few years ago.
It is a regular old thermostat for a Chevy/Ford with an adapter on it to make it a larger diameter. I even changed just the thermostat at a later date when I had problems with it heating.
old
04-22-2006 19:10:04
 Re: Oliver 60 thermostat troubles in reply to BEK, 04-22-2006 18:50:46
Thats where the problem is, the adaptor is to big around to fit. Seems that on the 60 that the hole is small then on the 77, 88 ,etc
KEH
04-22-2006 14:03:49
When I had a 550 I remember the dealer telling me the engine was the same in the 550 and the 66. Don't know if this helps or not.
KEH
