Tractor Talk Discussion Forum
JD carb rebuild kits
David Bate
04-21-2006 12:24:29
Can anyone please recomend a reliable company where I can purchase a carb kit for my John Deere 1944 BR.
Email address would be helpfull. Thanks in advance for any replies.
David
Glen in TX
04-21-2006 12:33:20
 Re: JD carb rebuild kits in reply to David Bate, 04-21-2006 12:24:29
robertscarbrepair dot com Other kits out there too but you'll get what you pay for on those and MS kits are too high for what they include and not always enough to properly rebuild one.
David bate
04-21-2006 15:11:44
 Re: JD carb rebuild kits in reply to Glen in TX, 04-21-2006 12:33:20
Thanks Glen for Robert's email address, will contact them, and hope it sorts out my "lumpy" running. Im used to tuning 4 & 6 cylinders, first experience of a twin cylinder and not sure what it should sound & run like.
Regards David
Mike M
04-24-2006 04:32:08
 Re: JD carb rebuild kits in reply to David bate, 04-21-2006 15:11:44
Unless they are under a load and working some "lumpy" running is normal. But I can't hear yours it may or may not be "normal"
RustyFarmall
04-22-2006 04:33:42
I have never rebuilt a JD carb, but from what I understand that lumpy running is caused by an idle curcuit passage being plugged with crud. I think this is where you need one of those long drill bits of the proper size that will get into that passage and clean it out. I think Robert's has those drills for sale also.
Glen in TX
04-21-2006 21:48:38
Check out his site and give him a call and he'll be glad to help you. He has videos on the JD carbs and tools for do it yourselfers also. If you have other problems holler at us on the JD forum and we'll be glad to help out.
