Tractor Talk Discussion Forum
42 farmall b flat vs. step pistons
ajs2379
04-20-2006 11:43:19
i have a 42 farmall b that im rebuilding. just wondered what the difference in power and compression i'd get if i changed from flat head pistons to step head pistons? also would i need to do any other work to the motor if i went with step pistons? thanks!
Red Dave
04-20-2006 12:45:32
 Re: 42 farmall b flat vs. step pistons in reply to ajs2379, 04-20-2006 11:43:19
I just got through with an overhaul on my '40 B. Pistons, sleeves, bearings etc. I used oversized (3-1/8"), step-head pistons in it. Stock flat-top compression (from the IH service manual) is supposed to be 105 PSI, I have 135+ now. I have not dyno'ed it yet, so I can't say if there is an increase in horsepower. You must keep your expectations realistic though, a 10% increase is still only an extra 1-1/2 to 2 horsepower, it won't turn it into a firebreather.
I did have trouble with the pistons touching the head. I believe it is because a previous owner had the head planed at some time in the past. I solved it by removing a tiny bit from each combustion chamber with a die grinder. Other than that, it needed no other modifications to the engine.
