Tractor Talk Discussion Forum
3 point add on
dweber
04-19-2006 07:28:37
I have A Case 730 that doen't have a 3 point and would like to add one. i found a company that makes them for this tractor however i lost the company name and information. I've found places that make them for older Ih jd and ac tractors, but not for this tractor.. I believe it was in canada however not certain. If anyone knows please chim in it would be appreciated.
Dirk
glennster
04-20-2006 06:27:01
 Re: 3 point add on in reply to dweber, 04-19-2006 07:28:37
i bought a 3 point from saginaw county tractor for my farmall m. they build a really great hitch. mine was 675.00 with the cylinders. the hitch even has removable pins on the top links so the hitch can float up if you are bush hogging. it will work on one way or two way hydraulics. they put a lot of thought into the hitch when they designed it.
Keith-OR
04-19-2006 08:21:56
Here is one that I bookmarked couple years ago. HTH
Keith & Shawn
Easy
04-19-2006 07:57:22
I bought mine from Saginaw Hitch. It is in Saginaw county, Michigan. I don't know about Case, but I know they do all the others. It is on the web too.
