Tractor Talk Discussion Forum
Turned out to be a bad day for Deere
barnrat
04-18-2006 19:24:33
third party image
After having a great day of plowing had to go and screw something up. wouldn't call myself a farmer without breaking something.
PJBROWN
04-19-2006 09:58:03
 Re: Turned out to be a bad day for Deere in reply to barnrat, 04-18-2006 19:24:33
What model Deere??? 3020/4020???
barnrat
04-19-2006 10:46:39
 Re: Turned out to be a bad day for Deere in reply to PJBROWN, 04-19-2006 09:58:03
2520 Diesel syncro
RodInNS
04-18-2006 19:32:14
Ahhhh, a deer with a broken leg.... time to do the right thing barnrat. Put it out of it's misery!
Rod
barnrat
04-18-2006 19:26:24
third party image
Here is another pic. Sorry bout the quality, took the pictures at sunset with my cellphone camera.
Mike M
04-19-2006 04:25:18
 Re: Turned out to be a bad day for Deere in reply to barnrat, 04-18-2006 19:26:24
Looks like the little triangle gusset was missing and it allready had started to crack ?
barnrat
04-19-2006 04:42:12
 Re: Turned out to be a bad day for Deere in reply to Mike M, 04-19-2006 04:25:18
Triangle gusset? Actually for some reason when they welded it together at the factory there was not alot of metal contact, being that at the joint there was a half of an adjustment hole. I Already had the other side break. When we welded that side back together we welded it together alot like the axle on my Massey allowing for alot more weld surface and strength.
jared in wi
04-18-2006 19:41:51
if you want to permanantly remedy that problem, there is a place in western iowa that takes wide fronts off of 4640"s and 4650"s and so on and convert them to fit under the New Generation sieres tractors. the web address is www.edbeem.com
