Tractor Talk Discussion Forum
which one?
wannabe in TN
04-16-2006 19:16:34
I just need a simple answer...I have limited funds, and a big need to buy a tractor that can mow my 10-12 acres of hilly pasture. The pastures are grazed, so manageable mowing, no debris in the field. Am I better off buying an old tractor? I'm not all that mechanically inclined, I just need to mow. I've been told to get live PTO and powersteering and a 3 point hitch. Other than that, any advice? The grass is growing as I type...help!
Blackhole49
04-17-2006 05:46:01
 Re: which one? in reply to wannabe in TN, 04-16-2006 19:16:34
Zero turns are great for just mowing, but good ones are $8-10,000 new and can be a maintaince nightmare used. I agree, a small used diesel compact is the way to go. My kubota uses 1/3 the fuel my 8n did and is much more nimble. After a mid deck, would never go back to a rear deck.
Mike (WA)
04-17-2006 08:23:11
 Re: which one? in reply to Blackhole49, 04-17-2006 05:46:01
Zero turns can also be a problem on slopes- the front wheels don't help keep you going straight across the slope, and they have a pretty high center of gravity. I'd go with the used tractor, but if you are on a budget, you'll find you cannot afford the 10 year old compact Japanese tractor that would be the ideal solution.
wfw
04-17-2006 05:12:26
if all your is gonna do is mow then have you consideres a zero turn mower?? some of them mow really fast while you ride and new go for 3000 to 4000 dollars. If you are gonna use it for other things also then I would get a tractor
Fawteen
04-17-2006 01:44:07
Well, I'm gonna disagree with both previous replies.
1. 8N's and small older Fords in general are way, WAY overpriced. They're not ideal mowing tractors either. I'm not saying they won't do the job, I'm saying they're not the best choice.
2. No way on the PLANET would I try to maintain 10+ acres with a walk behind. Never mind the work, who's got the TIME? I have 4 acres, and wouldn't dream of trying to do it with a walk behind. Besides, for the price of an industrial sized walk behind, you can get a pretty nice tractor.
One point I DO agree with is that if you're not mechanically inclined, or at least interested in learning AND spending the time to maintain stuff, then old equipment isn't for you.
My advice: Find a 10 year old (or thereabouts) Compact Utility Tractor by any of the big names: Kubota, John Deere, Massey Furgeson, or Ford, even Yanmar (who built most of the older JD CUTs) if there's a dealer handy. You'll spend a bit more, but you'll get a LOT more tractor.
LIVE PTO is nice but not essential for mowing, PS is the same. While it'd be nice to have, it wouldn't be a deal-breaker for me if the tractor is otherwise in good shape.
Hydraulics and a 3 point hitch ARE essential, and a diesel engine is way up on the list. The only advantage to a gasser is that it's easier to work on, but if you're not going to do your own work, go for the diesel. Cheaper to run, and they'll last forever with a little TLC like regular oil changes and keeping the air and fuel filters changed.
My 2�, your decision.
CLW
04-16-2006 22:15:43
I would look for a 8N Ford or maybe a little newer. You can find a nice one with a mower for $3500 or less. If you get a Ford like the 8N you wouldn't need power steering as they are light on the front. More so with a mower on the back. Live PTO is sure a plus but in open space like you are talking about you wouldn't miss it that much. It is when you get in tight corners you need it. Look in the photo ads at the left. Select "tractors" then put 133298 in the search. That would be a nice tractor for what you want.
Tom in TN
04-16-2006 19:38:13
Wannabe,
I live in Middle Tennessee on 150 acres of very hilly land. I have old equipment and I operate on a shoe string. I spend a great deal of time performing routine and corrective maintenance on all of my equipment. If you truly are not mechanically inclined, my advice to you would be not to buy any inexpensive, used equipment. Maintenance is a constant need on old equipment.
Having said that, I think that you are going to have to juggle your finances, your available time, and your mechanical abilities to select whatever will accomplish your goals. Honestly, on 10 - 12 acres, I'm not even sure that you need a tractor. You could probably get by with a large, walk-behind mower similar to ones made by Graveley or DR Mower.
Good luck on your decision.
Tom in TN
wannabe in TN
04-17-2006 07:07:59
 Re: which one? in reply to Tom in TN, 04-16-2006 19:38:13
Thanks for the great feedback. I have been told before that I don't need the headaches of an old tractor for that small a piece of land. But what kind of grass height/thickness can I expect a zero turn or compact to handle? I don't want this to be a fulltime job to maintain, but can mow more frequently than the 2-3 hay cuts we have been doing. I know I am asking way too much...there are so many factors to consider as one reply said...time vs money vs repairs
