Tractor Talk Discussion Forum
O/T hard start when warm f150
UncleTom
04-16-2006 12:10:47
Hi everyone. I have that hard starting when warm problem. No its not the battery or starter. It whirls it over just fine. I put a spark tester on the coil wire and cranked it over to test for spark and it has spark the second i turn the key. The fuel pressure is 34 psi. running and on hook the vacum hose from the fuel pressure regulator (which is new) and it has 42 psi. But the fuel pressure does leak down kinda fast. Would that matter. It dosnt act flooded or anything like that. It has had sea foam fuel conditioner added to the tank to clean injectors periodicaly since i have owned it. What should i be looking for?? Thanks in advance.
Bryan in Iowa
04-17-2006 11:06:15
 Re: O/T hard start when warm f150 in reply to UncleTom, 04-16-2006 12:10:47
sounds like a fuel pressure problem It should hold pressure and not bleed down after shut off,,you may have bad regulator , bad injector, or leaking fuel pump check valve.Any loss of presure will make it hard to start. Is there any fuel in vac line when you tak eit off the reg ? if so reg is bad .
UncleTom
04-17-2006 15:45:44
 Re: O/T hard start when warm f150 in reply to Bryan in Iowa , 04-17-2006 11:06:15
Bryan, there is no fuel in the vacum line when you pull it off. That is a new fuel pressure regulator about 3 weeks old. I think it is the check valve in the tank. Does that mean a new fuel pump module of some one mentioned putting a check valve in the presure line. I know that i have the over filling of the front tank syndrome from the rear tank.
UncleTom
04-16-2006 18:26:28
I just put a digital volt meter on the battery and i get 10.79 volts while cranking on a cold start. I didnt check a hot start voltage while cranking yet.
UncleTom
04-16-2006 15:59:38
It dosent seem like it is rich. Is there a certain resistance the coolant sensor and air intake sensor should read? I want to fix this before i wear the starter out. Thanks for all the help from everyone.
Leland
04-16-2006 18:16:42
 Re: O/T hard start when warm f150 in reply to UncleTom, 04-16-2006 15:59:38
Check the TPS they shoot craps and they won't start for anything
Bob
04-16-2006 16:15:56
Yes, there is a specific resistance for each sensor at a given temperature I'm 25 miles away from my service information today. Perhaps someone will post more detailed information, or check out GOOGLE.
Bob
04-16-2006 13:05:58
What is the fuel pressure WHILE CRANKING?
UncleTom
04-16-2006 14:32:30
 Re: O/T hard start when warm f150 in reply to Bob, 04-16-2006 13:05:58
The fuel pressure does run up to 42 psi when cranking but not right away. There is maybe a second or 2 before it reaches the 42 psi.
Bob
04-16-2006 14:43:05
 Re: O/T hard start when warm f150 in reply to UncleTom, 04-16-2006 14:32:30
What is the battery voltage while cranking?
Also, try boosting it from another vehicle. Does it start quicker when there is more power available?
Does it act like it's running rich on a hot start?
A bad coolant sensor or intake air temp sensor will amke the 'puter think it's cold, and give it too much fuel, making it act like it's flooded.
