Tractor Talk Discussion Forum
overheating 1957 super 88 oliver
rgruber
04-14-2006 18:17:10
question i have oliver overheating waterpump is fine check the thermostat there wasent one in i was told a lot of farmers took these out for some reason could it be possible i have a cacked head or the radiator is pluged although when looking in the radiator there is alot of water moving i have own this tractor for 3 years and just when i need it i have trouble thanks much.
noncompos
04-16-2006 19:23:27
 Re: overheating 1957 super 88 oliver in reply to rgruber, 04-14-2006 18:17:10
Oliver Power, my apologies; as usual, had my mouth in high and my brain in low--another post here re" an Oliver 77 overheating has a reply saying Manual sez must have thermostat in for proper circulation in those engines. (At least I has sense enough to leave myself a back door out re" Oliver idiosyncrasies..). Oh, well ...
noncompos
04-16-2006 12:43:50
Oliver Power: I'm a bit confused by your thermostat post...if running without thermostat means block is running hot, 90% of the old cars/trucks in AZ, NM would've burned up (the first thing we did with running too warm was pull the thermostat, and a lot of 'em didn't have one when we looked)...of course, I'm not familiar with Oliver, in case it's an Oliver or tractor idiosyncrasy...feel free to email direct if you'd rather not expose some part of my stupidity publicly, or clutter the forum, but I am curious.
J. Schwiebert
04-15-2006 04:15:57
Also have your cap checled. It should be a 4 psi cap. Also look at the water pump pulley. See if the belt is running on the bottom of the pulley. If it has the original pulley it well maybe and it should not be doing this. You did not say if the tractor was gas or diesel.
bradk
04-14-2006 20:06:23
My '55 super 77 ran hot until I took off upper rad tank & rodded out.I think only 3 passages were open.Is yours a presssure or non-pressure system? ~brad
old
04-14-2006 19:23:34
Had the same problem with one of my 77s a few years back. Found the cooling system was clogged up. I flushed it out with vinagar and it hasn't got hot since. It also doesn't have a thermostat in the system.
Oliver Power
04-14-2006 18:56:07
The thermostat needs to be installed. Without thermostat , coolant will bypass the engine , circulating through waterpump and radiator only. Your gage probably reads hot , even if the radiator doesn't boil over. Not saying the head isn't cracked. Thermostat does need to be installed.
