Tractor Talk Discussion Forum
sheperd engine rare or not?
oliver super 77
04-14-2006 18:09:02
Hello all i was wondering what a shepperd moto is worth if any one has any prices that they know of.
oliver super 77 puller gu
04-14-2006 18:29:43
 Re: sheperd engine rare or not? in reply to oliver super 77 puller gu, 04-14-2006 18:09:02
the motor looks to be 3 or 4 cylder cant rember,they look good shape wise but they are pretty small, i was just wondering what they might be worth?
Larry from md
04-14-2006 19:07:20
 Re: sheperd engine rare or not? in reply to oliver super 77 puller gu, 04-14-2006 18:29:43
The main value in a sheppard engine will it or its parts work to repair a tractor they ARE expensive.The tractor engines are large long stroke engines.If its small it might be a life boat engine.
Nebraska Cowman
04-14-2006 18:16:25
I was offered a Shepard tractor this winter an SD3 I think, supposedly would run but hadn't for a while and the tires were flat. He wanted $8500 and at that rate I'd guess he has it a while longer. yeah, they're rare but they don't everybody want one. third party image
Even bad boys are just as good as they can be
Trkr
04-14-2006 18:14:18
Depends on condition ,like everything else.How many cylinders,is it a genset,marine or a tractor engine?
oliver super77 puller guy
04-14-2006 19:12:42
 Re: sheperd engine rare or not? in reply to Trkr, 04-14-2006 18:14:18
Could any one tell me what a 2 to a 3 cylinder sheperd engine is worth its complete butt may be stuck
Trkr
04-14-2006 19:22:08
 Re: sheperd engine rare or not? in reply to oliver super77 puller guy, 04-14-2006 19:12:42
With the unknown factor you would assume the worst that its stuck,or cracked block and /or head.In that case they are not worth a lot.I have Sheppard tractors and engines ,if you can get me a number off a tag if it still has one,I can give you a little better idea of value.
04-14-2006 19:31:39
 Re: sheperd engine rare or not? in reply to Trkr, 04-14-2006 19:22:08
Hi trkr i dont have any idea about the numbers its quite away from my house, could u give a amount at the lowest and one at the highest, its eathier a 2 cyl or 3cyl and its orange if that helps.
Trkr
04-14-2006 20:06:44
 Re: sheperd engine rare or not? in reply to oliver super 77 puller gu, 04-14-2006 19:31:39
Sheppard made several models of 2 cyl engines,And if it is the one that goes in the SD-2 tractor they are pretty rare.Unknown condition,low would be a couple of hundred dollars. Good running SD-2 could easily be worth several thousand to someone restoring an SD-2 with a bad engine as they only made around two hundred of those tractors.The 3 cylinder Sheppard tractor was the most common with about 1800 hundred of those made,but they are still rare.About the same money for a 3 cyl.,maybe a little less.Several years ago I bought a model 17 2 cylinder Sheppard Navy genset WW11 vintage for $300.Also bought a SD-2 shortblock about 10 years ago for $1200. for a tractor I was restoring.One of the Sheppard tractors I have now is a SD-3 widefront ,in good shape complete,but the engine is out and dissasembled,paid $2,500.for the whole thing.Good friend just sold a complete running SD-3 for $3,500.Hope this helps some,Im in the Md/Pa area ,they were a little more common here as they were made in Hanover,Pa.
04-14-2006 20:13:39
 Re: sheperd engine rare or not? in reply to Trkr, 04-14-2006 20:06:44
Hi thank you for all the imformation u guys have gave me.
