Tractor Talk Discussion Forum
Case 444 electrical problem
Willy W
04-12-2006 21:41:03
Help!! I have a 1979 case 444 and have put a new Kohler 14 hp engine in, replaced the battery, voltage regulator, ignition switch, new wiring, checked the alternator output.... and burned thru 4 coils. New coil. Runs great.... 30 minutes and electrical death... burned coil. New coil...runs great.... 30 minutes....burned coil.
Any one with any ideas would be a great help. I love this tractor.
fixerupper
04-13-2006 10:35:10
 Re: Case 444 electrical problem in reply to Willy W, 04-12-2006 21:41:03
Is the coil bolted to the engine? If it is get it off of there. The engine shakes the coil to death in a very short time. Had that same problem with a 224 and after the coil was moved to the frame of the tractor the coil problems stopped. Jim
Bob
04-12-2006 21:53:47
1.) Are you using genuine Kohler coils? Generic automotive coils die a quick death on Kohlers, due to the odd point dwell angle of a Kohler.
2.) What is your charging system voltage?
