Tractor Talk Discussion Forum
Long backhoe help !
Joey Douan
04-12-2006 16:57:49
I have a super2 that sat for about 6 months when started it would run a little ways and shut off. we changed the filter cleaned the tank and strainer in the transfer pump.it will run now only at a fast idle, takes the throtle good, and will run up fine in neutral. when you put it in gear and engage the forward /reverse it jumps badly and will stall if you are not careful.
anybody had any experence with these?
any body with a W.A.G.(wild a__ guess)
Ray Hiller
07-03-2006 20:23:58
 Re: Long backhoe help ! in reply to Joey Douan, 04-12-2006 16:57:49
I'm relatively new to the tractor set but it sounds like the pump is not giving the engine enough fuel. Any leaks in the fuel line. Small / tiny leaks may be giving you loading issues. I resently purchased a Long loader backhoe. I can't find out what the model number is any help would be helpful. I can't find a S/N either.
