Tractor Talk Discussion Forum
Torque amplifier 300 utility
Tom Sawyer
04-09-2006 16:24:18
My tractor is an IH 300 utility. The t/a has'nt worked well for a few years. My problem is after pressure washing I was not able to get the tractor in gear. After starting in gear I am not able to stop the tractor ( no clutch). Further more when in 4th or 5th gear the tractor will stop but the T/A is whinning as if it is engaged but the lever is forword. After washing I found missing bolt at the cover under the battery. I'm assuming water entered there.
TDK
04-09-2006 19:01:18
 Re: Torque amplifier 300 utility in reply to Tom Sawyer, 04-09-2006 16:24:18
Tom, the T/A clutch is under the cover that battery sits on. Water can enter there if a bolt is missing. Sounds like the T/A clutch is not releasing. Remove the battery & the cover underneath. While engaging & releasing clutch pedal watch to see if clutch fingers are moving. If they are, then the clutch disk could be stuck to pressure plate. Let me know what you find.
Tom Sawyer
04-10-2006 16:07:51
 Re: Torque amplifier 300 utility in reply to TDK, 04-09-2006 19:01:18
Hi TDK, Thanks for the reply. I did what you said and I can see the fingers moving,Athough I can see the clutch seperating from the pressure plate. Does this mean it still could be stuck? If so do you know of an easy fix? Or should I ask?
