Tractor Talk Discussion Forum
Bio Diesel
Animal
04-07-2006 16:02:48
Most my tractors are multifuel John Deere, I am thinking seriously about trying to make this bio diesel and see if it will burn in my old tractors, today gas has taken another jump to $2.54 and the radio says its on its way much higher, I don't know how much higher I can stand!!! This high fuel is just about to break me, as I farm organically. I have got to try something different.
Animal
04-08-2006 09:55:32
 Re: Bio Diesel in reply to Animal, 04-07-2006 16:02:48
Thanks for your input fellas that is exactly what I needed to know. Gary the soy diesel has not caught on here yet, would like to see it pretty soon. I would like to think that if I have to pad some ones pockets that It would be the American Farmer and not the greedy oil companys owned by who only knows!
Errin OH
04-07-2006 19:33:21
Well just do your research first before you spend a dime. I got into it it for a while but have all but fell out of it now. I'll say why in a minute. Avoid anything to do with a site called "Journey to Forever". Bunch of quack's. Try the link below or BioDieselNow.com
While I can't speak to the dual fuel aspect of it, I can give you a few things to think about concerning bio.
The Bio PITA - "You" have to go fetch the stock. Its a real PITA to travel to all your stops only to come home with 5 gals of veggy oil because somebody came around and sucked it all out of the tanks. Ever price locking oil tanks?????
The Bio Trap - There is no way on Gods green earth you can make it for 70 cents a gallon. I don't care how much you make in whatever kinda system. By the time you figure chemicals, filters, electric, labors, fuel to fetch it, and equipment, Tain't, no way.
The Bio Curse - More a diesel issue than bio issue. The bio does act like a solvent and will require a few filter changes to rid your tank of diesel varnish's and crud. After the inital shock (few tank fulls) it tends to go away. But do replace any rubber hoses in the fuel system as it will eat them up.
Da Insurance Man - He is closely related to the Fire Marshal. Get their blessings up front. One of the regular bio makers just burnt down his house. Ask what he should tell the insurace company. 99% told him to say it was a grease fire, as "technicly" it was since the over heated oil flashed on him. I doubt the insurance fella's count boiling 40 gals of veggy oil as the same as a grease fire in a frying pan.
So why have I basicly quit, I found I was spending about $3.00 a gallon makin my own. By the "time" (figured cheap labor $10 hour) I fecthed the oil, filtered it, pumped it, heated it, mixed it, seperated it, washed it, washed it again, and again, and again and then finally dried it by heating and pumping it again, again, and again. Not to mention the batches that failed (turn to gunk) or the gallons of glycerine and wash water you have to get rid of. I can get farm diesel or fuel oil (my main uses) for 2.20 and 1.85 a gal respectively, and takes all of 5 mins to fill the tank.
Don't get me wrong there is a place for in the future. It's just not the fix all great home brew they claim it to be. Now put diesel at 4+ a gal. Different story.
IaGary
04-08-2006 05:58:05
 Re: Bio Diesel in reply to Errin OH, 04-07-2006 19:33:21
I agree with Errin about trying to refine your own from used veggi oil, not enough used veggie oil to make it worth while.
But here in Iowa we can buy biodeisel that is produced from soybeans.
The cost on soydiesel is about $2.00 per gallon
I use a 5% blend of soydeisel, 95% diesel because if you use it straight it is hard on the rubber hoses and fittings.
But every gallon used helps the farmer and helps lower the cost of diesel.
Check with your fuel supplier and see if he will offer soydeisel. If your close enough to a plant he might do it if there are enough interested.
Just my 2 cents. Gary
John M
04-08-2006 10:50:37
 Re: Bio Diesel in reply to IaGary, 04-08-2006 05:58:05
Since when is B100 hard on hoses and such? New one on me,and I have been using it for over a year now. How long does this take?
Errin OH
04-10-2006 09:47:51
 Re: Bio Diesel in reply to John M, 04-08-2006 10:50:37
John, Somewhere around 93,94, 95 most if not all car makers switched to viton (sp) and quit using natural rubber products. So just about any late model vech would not have these issues. Older trucks and tractors likely would unless changed. If you go to the link and search on rubber and/or hoses you'll find all the info you need to know.
