Tractor Talk Discussion Forum
gravely tractor is smoking and all oil is going up
troy perdue
03-15-2006 16:55:57
I think i need new rings can i change just the rings and is there a car ring that will fit please help
teej
03-16-2006 09:38:51
 Re: gravely tractor is smoking and all oil is goin in reply to troy perdue, 03-15-2006 16:55:57
You need to be more specific about the Gravely. Is it a 2 wheel tracotr or a 4 wheel?
They made several of both that are similar, but in there own way different. Depends on the model and its age.
Some had there own engines, Model L, started being made in the early 1950s, or earlier
These all use the same rings regardless of exactly what year. Stopped being made in the mid 70s.
Some had Kohler Engines Sometime around the late 60s these came about, kind of replaced the ones with the Gravely engine, design of the machine unchanged except the engine.
Parts can be gotten from any Kohler dealer, as well as NAPA and several other aftermarket parts suppliers
Some had Briggs Engines Later 70s I think Available from any Briggs and Stratton dealer, as well as aftermarket sources. Mostly found on the 4 wheel tractors
and Some had Onan Engines.
some even had Robin engines, but those are the fairly new ones from the later 80s
Parts are still available for them all. Onan parts are a tad pricey however.
I strongly suggest you join this Yahoo Group.
Link
Its 100% free, there are over 2500 members, and its extremely active. Its well moderated to keep spam out. Post there, and you"ll get more help than you"ll ever need, including places you can order the parts you need, obtain free operator and service manuals, and also parts manuals.
Good luck fixing it, You"ll have a difficult time finding a comparable machine in today"s market.
Tim B from MA
03-16-2006 08:13:56
You didn"t give any details, but you might also check that the crank case breather is working. Presure in the crank case can force oil into the cylinders.
bigreddm
03-15-2006 17:11:00
you might need more than rings. if you don"t have the ability to measure the bore and compare it to the specs( in a gravely I think it"s a kohler motor) take it to a machine shop, have the bore measured and find out if the bore is out of round. If the machinest says it is still in specs buy the RIGHT rings according to the manual.
