Tractor Talk Discussion Forum
1956 JOHN DEERE 420W
JIMMY MONGER
03-15-2006 06:09:42
CAN ANYONE TELL ME WHERE TO FILL THE HYDRAULIC FLUID FOR THE THREE POINT HITCH. ALSO, I HAVE BEEN TOLD TO USE TRANSMISSIN FLUID INSTEAD OF HYDRAULIC FLUID. ANYONE KNOW ABOUT THIS?
THEkyroastnear
03-15-2006 14:55:27
 Re: 1956 JOHN DEERE 420W in reply to JIMMY MONGER, 03-15-2006 06:09:42
i also own one that wrong fluid in hyd. mine would jerk like the system was starved for oil. drained & refilled mine with 30 wt. non detergent works good now filler cap under seat petcock on back will let you know its full as others posted
THEkyroastnear
03-15-2006 14:50:32
LATarhill
03-15-2006 07:46:25
Jimmy, the 420 should use 20 or 30 wt motor oil. This is called for in the manual. I have two 420T's, one had hydraulic fluid in the lift when I bought it and it worked real slow and was weak. Changing to motor oil fixed it. Steve
Jim Peppers
03-15-2006 07:19:52
I use the trans/hyd. from SAM's CLUB itis about $22 for 5 gal. The fill plug (1-1/4) under seat cushion.You can also remove the vent cap at the back of cushion and pour in there. Trere is a petcock on the back of diff. housing to the right of 3 point top link, open the cock and add fluid until it runs out the cock. Good luck. Jim
jimmy monger
03-16-2006 05:55:20
 Re: 1956 JOHN DEERE 420W in reply to Jim Peppers, 03-15-2006 07:19:52
jim, do you have any photos of fill area? there is what appears to be a freeze plug under the seat, in the middle of the seat frame area, wit ha phillips screw in the center. Has someone put a freeze plug instead of cap possibile? im baffled.
