Tractor Talk Discussion Forum
pto spins backwards
rice fields
03-11-2006 11:17:53
I just recently bought a 1956 john deere 70 diesel and to my suprise the pto runs backwards. Is this standard on the 70 or how do I change it
Bison
03-12-2006 20:46:22
 Re: pto spins backwards in reply to rice fields, 03-11-2006 11:17:53
The only engines I ever witnessed turning backwards where 2 stroke diesels, Back in europe we had a mann tractor, That a guy could start going the other way by letting it die and on the last stroke the compresion would sling it back and it would fire up in the other way.
It could ruine the engine cause the oilpump runs the wrong way too.
JIm in mi.
03-12-2006 06:36:03
Someone may have changed the pto unit on the back of the tractor without changing the internal shaft and gears to match. They either changed a non live PTO unit to tractor that had live PTO or vice versa. One drives off the crank gear to be LIVE and the other drives off the Trans gear like a JD G.
Mike M
03-12-2006 04:52:08
Those have a standard PTO runs the same direction as every other tractor, Ford 8n,IH H,M
Check the engine and make sure it isn't running backwards,once in awhile they could do that. Usually happens if it almost stalls and comes back to life,problem is the oil pump runs backwards then and the air cleaner is now the exhaust. So if it ran long at all this way it may be junk.
rice fields
03-11-2006 19:43:29
My pto runs counter clockwise. ALL my other tractors my neighbor farmers all run clockwise. Everybody i know who has a tractor has a clockwise turning pto
Bob
03-11-2006 17:29:07
Backwards as compared to WHAT, an IH Cub????
