Tractor Talk Discussion Forum
filling tractor tires with calcium/water
ALBAUTZ
03-08-2006 07:34:46
My 955 JD has one tire with and one tire without calcium. Is filling with calcium/water a DIY possibility? How?
TyTX
03-08-2006 20:07:23
 Re: filling tractor tires with calcium/water in reply to ALBAUTZ, 03-08-2006 07:34:46
A few things to think about re: Calcium Chloride (CaCl)
1. It weighs MORE than water, which weighs MORE than windshield washer fluid or anti-freeze. (The idea is to add more weight and that is why CaCl is used.)
2. CaCl should be loaded into "BLADDERS" approved for that purpose. "Inner-tubes" are for holding air and for floating down the river on hot days. If I ever had a valve stem rot out from CaCl, you can bet I'd have a bill for damages on the desk of the dealer who sold me an inner tube but charged me for a bladder.
3. My 14.9 x 24 rear tractor tires hold a bit over 50 gallons each. That equates to about 600 lbs. of antifreeze/washer fluid; 800 lbs. if I fill them with plain water or an excess of 1150 lbs. if I fill them with CaCl. You choose what you want to use for weight.
4. CaCl has been the ballast of choice because it puts the weight right down on the ground from inside the tire. You can run with lower tire pressure and get great traction. I can't imagine loading up 1150 lbs. of wheel weights, can you?
My 1965 MF2135 has had CaCl in the tires for as long as I know. Last flat I had, I took the wheel down to the rim and repainted. Nothing but surface rust and no pitting. Most of the inner wheel rim had no rust at all. I painted them with Hammerite and don't expect any trouble for another 40 years.
Don't be afraid of Calcium.
Enrique Fernandez
01-29-2007 07:07:21
 Re: filling tractor tires with calcium/water in reply to TyTX, 03-08-2006 20:07:23
I need information on getting truck tires filled with calcium-water mixture. The size of the tires are 395/85-20 inch rims. The tires are on a HIMARS Simulation Trainer located at Redstone Arsenal in Huntsvilla, Alabama.
I would like to know the nearest place to get this done. Thank you very much.
Enrique
riverbend
03-08-2006 16:28:58
I'd get rid of the calcium chloride and use weights unless you can get better than usual inner tubes. The CC ate the valve stem out of a Korean made tube in a couple years. The rubber part of the tube is perfect. I'm going to take it to my tire guy and have him put a new valve stem in it.
sjh
03-08-2006 13:05:31
How many times does this need to be asked. Please do a search. You will get 1,000,000 results!!!
old
03-08-2006 08:25:37
My self I use windshield wiper fluid, it doesn't rust the rim if you get a leak. Also filling tires is simple. Drop me an e-mail and I'll send you a page from a 1935 JD owners manual that tells you a few ways to do it and al of them can be done by almost any body. Shoot one of them can be done in your sleep LOL
ejr-IA.
03-08-2006 08:19:44
Personaly I don't like calcium in my tires It's hard on rims cost more to fix a tire when you have a flat.In the long run I'd rather have wheel wieghts for the needed ballast.
MF Poor
03-08-2006 08:14:57
There's nothing dangerous about salt water, other than causing rust if it gets on metal. No problems there. Go to NAPA and get the adapter to hook a hose to the valve core. Get a small pump. The ones powered by a drill are satisfactory. For what a tire service will charge, you can own the tools to do hundreds of tires.
FatRedneck
03-08-2006 07:48:47
I suggest you call around to the tire shops in your area and find someone to put the calcium in your tires, cause doing it yourself is difficult and can be dangerous if not done properly
JMS/MN
03-09-2006 12:52:20
 Re: filling tractor tires with calcium/water in reply to FatRedneck, 03-08-2006 07:48:47
What is dangerous?. Spill some on your hands- wash them. Not going to eat through you or your clothes. With proper tubing/piping, you can gravity feed it into an inner tube. Or use a pump. Been around for over half a century. Only reason it rusts through rims is because people ignore leaks instead of fixing them. Much ado about nothing.
