Tractor Talk Discussion Forum
JD powershift transmission
Willy P
03-06-2006 19:43:30
My JD 4050 maybe having transmission problems when you shift a gear it jumps,it does not shift smoothly and in some of the gears maybe 13,14,9 somewhere in that range it will slip under load,it just is not functioning properly.Could it be a valve sticking or maybe the accumalators are discharged? Please someone give me some advice.
msb
03-07-2006 07:20:13
 Re: JD powershift transmission in reply to Willy P, 03-06-2006 19:43:30
Take it to a dealer and have them check it out.They should have a set of gauges to put on the valving.It could be a blown gasket or several other things.Probably nothing serious.The tractor may not even have to be split to repair it.An accumulator should not cause the transmission to slip for more than a second or two.
