Tractor Talk Discussion Forum
Which one would you fix??
old
03-05-2006 12:40:45
If you had say a MH 44 and a MH 30 but not enough parts between the 2 of them to fix them both which one would you fix? I know the 44 is bigger/more HP then the 30 but which one is worth more the 44 or the 30. Most parts look like they would fit either tractor. Thanks
sammy the RED
03-05-2006 20:30:25
 Re: Which one would you fix?? in reply to old, 03-05-2006 12:40:45
Don't fix either one.
Go get a 33 and use the parts to fix that up.
toolman
03-05-2006 14:54:14
I got a tea 20-85 use it all the time, got a 44 sitting out back hardly ever touch it, 44 is a good tractor but the little fergie does all i need it do to then some.
RustyFarmall
03-05-2006 14:50:00
I don't think you should fix either one, just leave'em set and I'll be down next week and get them out of your way.(: Actually, I think I would fix up the 30, not too many of those around.
Leroy
03-05-2006 14:40:53
Would supprise me if any parts would switch and the 30 there are a lot fewer of them around than a 44
old
03-05-2006 15:27:25
 Re: Which one would you fix?? in reply to Leroy, 03-05-2006 14:40:53
Well I know the hyd tank, seat parts and some of the sheet metal will work on either. I also know the 30 runs but don't know yet about the 44. Guess I'll play with the 30 first and then go back to the 44.
