Tractor Talk Discussion Forum
lycoming piston rings
ej jurt
03-05-2006 06:57:56
i have a lycoming 0-235 engine and need rings
for pistons. they are the beveled style.
its for an old snow plane i have. dont want
to buy from lycoming about 900 dollars for aviation approved its an old apu for WWII
b-17 preheating unit. somebody told me some
older tractors used those kind of rings
there pretty big around 4 1\2 inches round
i have all demensions any help thx ejh
Langoley
03-06-2006 09:17:28
 Re: lycoming piston rings in reply to ej jurt, 03-05-2006 06:57:56
There are some on Ebay!!! The guy has some listed for $225 and he has 9 sets.
Areo
03-05-2006 13:18:09
Back in the 60's when I played around with snow-planes I got my parts from adds in "Trade-A-Plane" flyer. I just "googled" and they are still publishing. I got main and rod bearing sets for $16 back then for Continental engines.
HTH
Areo
woodache
03-05-2006 12:28:51
 Try Here Sell Gov SurplusRe: lycoming piston rings in reply to ej jurt, 03-05-2006 06:57:56
Try these people, they have been dealing in this type of stuff for over 60 years. If they dont have any they may be able to direct you to a supply. Just make sure you tell them it is a GPU engine.
Try an aircraft engine OHaul shop ask if they have some used takeouts. Most airplanes may be usable for your application. As they dont let them get that bad
Link
03-05-2006 08:41:36
no offense, a snow plane runs on snow. it has 3 skies, cockpit, sterring wheel,pusher prop,
leaf springs,shocks on back 2 skies,
only flies at 70mph when you hit approach or ditch.
thx for the help will try suggestions.
your a/p mech. ejh
Bob-MI
03-05-2006 10:49:56
 Re: lycoming piston rings in reply to [email protected], 03-05-2006 08:41:36
Sorry,
Just a little overly concerned about non-standard airplane engine parts. Didn"t understand the application.
My bad...
Bob - MI
03-05-2006 07:44:37
I am involved in the manufacture of aircraft parts and have had some experience with companies that reverse-engineer high spares rate parts. There is proably someone out there that is making these for the application that you are seeking but you must ensure that you get parts that are certified to FAA standards. The reason is simple, you could die from sub-standard and/or incorrect parts. I would look for an FAA certified rebuilder and get them give you direction. I know of a company in Texas that reverse-engineers parts for Lycoming turbines and I won"t get in a helicopter without asking the operator where they get hot-section replacement parts from.
All this assumes that you are a certified A&P mechanic or you are working with one in the first place. A friend of mine lost his father that had an air charter service some years back. He started doing very simple things like plug changes and then became a little more bold and got deeper involved with repairs and worked on one the engines on his Cessna 310 that was exhibiting sporadic cutting out. He and a load of passengers were killed when he took off and lost that engine and stalled just past the fence. They crashed in the back yard of a homeowner nearby where the homeowner saw them struggling to get the doors open while they burned to death.
jdhabg
03-05-2006 07:35:29
Try Otto Gas Engine Works (410) 398-7340. If he doesn't have them he can make them.
ejr-IA.
03-05-2006 07:35:24
Try these guys they make rings. www.pistonrings.net/
Green B
03-05-2006 07:33:36
This may help Link
