Tractor Talk Discussion Forum
Putting Fluid in Rear Tires
N. TX Tim
03-03-2006 20:28:04
Had calcium in the rear tires of my Case. One tire developed a leak. Removing the old tube from the tire, it pulled apart, so figured I should go ahead and replace both tubes as they were 25 years old. Don't need any down time during hay season. I am planning on using windshield washer fluid...what is the easy way to do this? I read a post a while back and someone was offering to email illustrations/instructions. Any help would be appreciated. Also, does the tire have to be filled all the way to the valve stem...or is it ok if I just put say 50 gallons in each side.
Thanks,
Tim
RJ-AZ
03-04-2006 18:13:34
 Re: Putting Fluid in Rear Tires in reply to N. TX Tim, 03-03-2006 20:28:04
I beleive that Calcium Chloride mixed with water in the proper ration makes it weigh almost 12# per gallon. You can run as much fluid per tire as you want to and most Ag tire dealers should have a chart as to how much water a particular tire will weigh at whatever % of fill used. You have to see some pretty consistent below freezing weather to freeze plain water in a tire.
Dave Sherburne NY
03-04-2006 12:06:41
I just finished filling the tires on my MF35
last week. Go to Gemplers.com, and look up part#
AQF1 $13.95 for an adapter to hook a garden hose to the tractor tube. My fluid was in a 55 gallon
plastic barrel. In one barrel plug I put a valve
with a hose connector on it and in the other
I had a fitting where I could pressurize the barrel. Put the valve stem on the top , Put the adapter on the tube. Lay the Barrel on its side hook the hose between the tire and the barrel.
Open the valve. Pressurize the barrel MAXIMUM
10 lbs. MAXIMUM 10 lbs. and in about 20 mins the fluid begins running out the air outlet on the adapter . shut off the valve.remove the adapter put the valve core back in the tube
and do the other tire the same way. If you are where it doesn't freeze, you can
probrobly just hook up to the water faucet. OH, I left the barrel right on the truck when
I filled the tires. 12x28 tires .Less than 50
gallons to fill each tire. There is a chart some where that tells how much a certain tire size holds. Another thing, you have to hold the
tire up with a jack to eliminate the flat spot
on the bottom when filling
Bob
03-04-2006 09:44:47
CaCl is a LOT heavier than wiper fluid. If you read the weight, check out RimGard, made from beet juice. It's non-corrosive, non-toxic, and heavy.
old
03-04-2006 07:30:33
Tim, drop me an e-mail and I'lll send you a copy of the page from an owners manual that tells how to fill your tires with fluid
Burnie
03-04-2006 02:08:08
Tim,
It should be fine to put 50gals in each tyre. Any amount is ok so long as you leave some space for air. I use and adaptor that fits onto a garden hose, (I've never put washer fluid in as freezing is not really an issue in Australia) and postion the valve stem where I want the height of the water to be.
TRC
03-04-2006 01:25:24
Tim, it was Old who had the document describing how to add liquid ballast to the tires.
CRUSADER
03-03-2006 23:44:22
Hey Tim,
Where at in North Texas are you? I will most likely be looking at getting a place in the Panhandle in a couple of years, currently I am in Korea, and will be headed to Abilene in September.
It's been a few years, but the easiest way to put the fluid back in them tires is to go and get an adapter. The only kind I have ever used is sold by Milton and can be purchased at most Auto Parts Stores, TSC, Gebos, and I am sure the CO-OP or local feed, seed, and fertilizer stores have them also. You remove the valve stem and hook it up to the the threads on the core where you screw the valve stem on. hook the water hose to it, put the tire at about 9:00 or 2:00 o'clock position and start filling. There is a vent on the adapter to bleed the air off. Once the water starts coming out without air you should be at the required level. You could also put a funnel into the hose and pour the anti-freeze or whatever else into it if needed or required. Hope this helps.
Jim
N. TX Tim
03-04-2006 06:38:51
 Re: Putting Fluid in Rear Tires in reply to CRUSADER, 03-03-2006 23:44:22
Jim,
I will look and see what I can find...I appreciate the info. We have a funnel/hose/adapter that fits over the outside of the valve stem that we use to fill our A.V. (artificial "you know what" that we use to collect our stud). I can use that but it will be slow going for sure. I downloaded a chart for tire capacities and I think it took something like 70 gallons for my size tire. I use this tractor for haying, shredding and pulling my drill, so I am mainly going to do this to maintain stability.
We live just west of Wichita Falls...quite a ways from the Pan Handle...but we are only a couple hours from Abilene.
Thanks,
Tim
