Tractor Talk Discussion Forum
what tractor do i have?
mark111
03-03-2006 16:23:13
i recently bought a ford tractor that nobody knows the model. it has a ford fergeson clip on on the grill ( tractor supply has these and possibly bought for any reason)but an embossed 8n is stamped on the block. i dont know what i have. my rear wheel lugs are spaced 8" and a friend said it couldnt be an 8n because of the bolt pattern , which is tighter on a 8n.the tractor appears to have been red originally, i dont know if that matters. the nameplate below the steering column is readable and says it was made by ford motor co. in michigan whith 10 or so patent numbers.any help would help. thanks , mark
Jim.UT
03-03-2006 16:30:45
 Re: what tractor do i have? in reply to mark111, 03-03-2006 16:23:13
You could have a mutt. The engines were interchangeable between the 9N, 2N and 8N. The link below will help you figure it out.
An 8N should not have a Ferguson badge, but a 9N or 2N will. But a 9N or 2N would not have 8N cast into the engine block.
