Tractor Talk Discussion Forum
tubes and tires
Dane in PA
02-28-2006 15:46:43
I am changing the tires on my 1952 A. the ones on it were 12.4x38 and the ones I'm puttin on are 13.6x38. would the tubes that were in the original tires (stamped as: 12.4x38) fit with the 13.6x38 tires that I'm putting on, or would I need new tubes? I'd like to save a few bucks because I price checked new tubes, $45 each. thanks, Dane
Leland
02-28-2006 20:29:49
 Re: tubes and tires in reply to Dane in PA, 02-28-2006 15:46:43
Those tubes are over 50 years old do yourself a favor replace the tubes ,saw many a tube fail when people tried to reuse them this old , made many a service call to change them out .
old
02-28-2006 18:07:34
Most tubes will fit a number of tire sizes. I.E a tube can be marked for 11.2, 12.4, and 13.6. etc you will probably be ok. Look on your tubes when you change your tires and they should tell you what size tires they will work in.
larry h
02-28-2006 17:15:38
we get 30.00 for tubes email with your needs we sell wholesale
Greg_Ky
02-28-2006 15:50:38
I Did the same thing on my backhoe when I replaced the tires six years ago and it worked just fine. (the tubes will fit a pretty wide range of tire sizes)
