Tractor Talk Discussion Forum
Farmall A Planter
Csutton
02-27-2006 19:54:47
Does any one have any pictures of how the planter box attaches to the tractor?? Does it need to run off the pto or is it ground driven? Bought the tractor w/ planter, cultilvators, and belly mower but only the belly mower was attached. Trying to see if we're missing any parts. Thanks
mike wood
02-27-2006 21:29:11
 Re: Farmall A Planter in reply to Csutton, 02-27-2006 19:54:47
The planter we used to have, had a gear that attached to the left rear wheel housing. If I remember right there is a cover on the inside housing that can be removed. The gear bolts to a shaft and a chain runs the planter. The fertilize distributor runs off the planter with a chain. There are bolt holes on the right side for them to bolt to. Hope this helps.
