Tractor Talk Discussion Forum
JCB 3C II Identifying engine
Greg Cigana
02-27-2006 15:43:09
Help!
I have a JCB 3C II loader+backhoe and i cant correctly identify the engine. Although branded a JCB 3C II, the name plate attached to the frame LHS front indicates a Nuffield Tractor 4/65. Model number 65B/1 120121. the engine has stamped lowerblock LHS: CCJ 1014.
the back of the head has stamped:498PS 1777 31767 86K6225.
The injection pump is a CAV rotary on the RHS (viewed from the drivers seat) the fuel filter is above the injection pump. the fuel lift pump is on the LHS.
I hope some one can help
Greg.
Jim Hessler
03-31-2007 15:25:08
 Re: JCB 3C II Identifying engine in reply to Greg Cigana, 02-27-2006 15:43:09
Chances are that you have a (British Leyland). I'm currently restoring a Jcb 3c III, it as well is equipped with a British Leyland. I did'nt learn of this until I found that the engine was in need of main and connecting rod bearings. I'm not sure how to identify the exact engine model by the plate, if you find out please let me know. thanks.
speedbuff
04-06-2007 07:44:37
 Re: JCB 3C II Identifying engine in reply to Jim Hessler, 03-31-2007 15:25:08
the engine id number is stamped on the top of the engine block on the right hand side of theat rear at the head mating surface just outside the head scrape away some dirt and you will find it let me know if you need any other info cheers the leyland guy
Majorman
02-27-2006 23:49:57
It will be a Leyland. The Nuffield 4/65 had a Simms inline pump. Leyland took over BMC who made Nuffields and dropped the name.
Try Link
Greg Cigana
02-28-2006 16:37:18
 Re: JCB 3C II Identifying engine in reply to Majorman, 02-27-2006 23:49:57
Thanks for your help guys, I"am a little closer to my quest for an identity.
Greetings from Sunny Sydney Australia..
Greg
RodInNS
02-27-2006 19:10:07
Sounds like a Leland.
Rod
seanTN
02-27-2006 18:55:54
It's probably a BMC (british motor company) or a Leyland diesel. Nuffields were discontinued in '69.
shawn morrison
02-27-2006 16:40:47
COULD IT BE A PERKINS ? JCB USED ALOT OF THEM
