Tractor Talk Discussion Forum
What HP for an 21 hole grain drill?
JD 50 owner
02-27-2006 09:37:19
What kind of horsepower will be required to pull a 21 hole grain drill in loose soil? Can I pull it with my JD 50 - approx 30 hp is what it is.
Thanks in advance.
buickanddeere
02-28-2006 06:50:47
 Re: What HP for an 21 hole grain drill? in reply to JD 50 owner, 02-27-2006 09:37:19
21 run not 21 holes. Are you pulling harrows behind? Kind of soil, moisture, hills, how worked up is the soil, seeding only or fertilizing at the same time, desired ground speed?
txgrn
02-27-2006 16:41:13
Pull it behind your (isuzu would work) pickup truck.
steveormary
02-27-2006 10:06:16
JD 50
I would think you could go right along with it.
steveormary
Bob
02-27-2006 10:30:34
 Re: What HP for an 21 hole grain drill? in reply to steveormary, 02-27-2006 10:06:16
There's a HECK of a lot of difference in draft between double disc openers, single disc openers, and hoe openers.
I guess it would help if he had posted as to what type of openers he has!
JD 50
02-27-2006 10:57:23
 Re: What HP for an 21 hole grain drill? in reply to Bob, 02-27-2006 10:30:34
Hi, this drill has double disk openers...mid 70's model...
THanks!
steveormary
02-27-2006 17:31:26
 Re: What HP for an 21 hole grain drill? in reply to JD 50, 02-27-2006 10:57:23
Jd 50
Hook it up and try it out.
steveormary
