Tractor Talk Discussion Forum
International M Farmhall
Joe555
02-25-2006 17:27:04
Posted recently about M locking up in gear. Took the shifter off and discovered the channel that
runs the reverse and first gear isn't attached to anything. When using a screwdrive the channel moves freely with both ends not attached to anything. Now if I put shifter back and try shifting to 2,3,4,5 the tractor acts like two gears are engaged. Whats up????? ??
Wayne Swenson
02-25-2006 19:52:32
 Re: International M Farmhall in reply to Joe555, 02-25-2006 17:27:04
Did the shifter fork break off while in 1st or Reverse??
You may have to remove the transmission cover to see what went wrong.
Joe555
02-26-2006 19:02:40
 Re: International M Farmhall in reply to Wayne Swenson, 02-25-2006 19:52:32
The shifter appears to be in good shape with fork and nothing broke off. The problem all started with shifter sticking in Reverse even though the tractor would not reverse. I took a hammer and lightly taped the shifter and it dissengaged to nuetral. I could then shift into 2,3,4,5 and tractor would move in these gears. When I tried to shift into Reverse the shifter would go into Reverse but tractor would not reverse. With recommendations from all I investigated by taking shifter out and aligning rails but reverse and lst gear rail moved freely. I think this rail should be attached to something. Hate to take cover off Big Job....
