Tractor Talk Discussion Forum
Internatinal Farmall M Tractor Clutch
S404
02-22-2006 21:24:27
Clutch Pedal locked in Reverse. Tractor would
not move. Shut tractor off and tapped clutch pedal
out of Reverse and now tractor will only engage
with 4 and 5th gear. The other gears won't work
Any suggestions. Will I need to take complete
top cover off to realign the gears??? Looks like
quite the job with seat and even gas tank bracket
extending on that platform.Any help would appreciated... This is my Farmall M Tractor
joe55
02-25-2006 17:19:09
 Re: Internatinal Farmall M Tractor Clutch in reply to S404, 02-22-2006 21:24:27
Followed your suggestions and removed shifter
and looking down tube were 3 channels. The channel
that runs the Reverse and First gear is moving
freely not attached to anything. I can take a screwdriver and move it back and forth and see
both ends which are not attached to anything. Now
the tractor is locked in lst gear I believe. If I put the shifter back and shift to 2,3,4,5 the tractor acts like its in two gears. Whats up??
Randy_NE
02-23-2006 13:22:26
Hopefully you just have your terminologyy wrong ; )
I think what you need for info is below.
Works the same for M's & H's.
Randy
Question
02-22-2006 21:49:28
I all ways thought that a clutch pedal hooked up to a clutch and a gear shift hooked up to the gears.
