Tractor Talk Discussion Forum
JD400 steering
ultrasteve
02-17-2006 06:20:16
I have an older backhoe. The steering is very loose. In fact, I can turn the steering wheel 2/3 to 3/4 around before it moves the linkage.
I don't have a manual yet (just ordered), but I'm hoping there might be an adjustment in the steering box?
Anyone here have suggestions? Thanks
ultrasteve
02-18-2006 05:54:59
 Re: JD400 steering in reply to ultrasteve, 02-17-2006 06:20:16
Thanks Tom!
It"s only +1 degree this morning, so I"ll probably not look at it this weekend, but I do appreciate the advice.
Are you familiar with the hydraulics on this unit? The hoe works great, but the loader shutters a little bit. I had heard that perhaps there are seperate hydraulics and that maybe the loader hydraulic fluid is low....any comments?
I just got this unit, so there is a lot about it I don"t know. I did just order a manual though.
Thanks again!
I hope you"re warmer than we are here in Michigan!!
Tom in Central Pa
02-17-2006 13:18:08
No real adjustment in the "box". The valves are set with shims, that doesn"t change.
Usual looseness, from the top down, There is a pin through the piston, and a link, nicknamed the "dog bone". The dogbone hole becomes enlongated. This happens on either end. Replace the dogbone. to look in on the dogbone, remove the half-moon cover off the side of the housing by the clutch pedal. The lower end is pinned likewise to a shaft. The Shaft has a tapered & splined end, with an arm on it. This connection may be loose. otherwise look for usual loose tierod/draglink ends, loose bushings etc.
Tom in Central Pa.
02-17-2006 17:39:23
 Re: JD400 steering in reply to Tom in Central Pa, 02-17-2006 13:18:08
Correction: The half-moon cover is above the brake pedal, the arm and shaft splines are visible, if you remove the tin cover by the clutch pedal.
ultrasteve
02-18-2006 05:56:29
 Re: JD400 steering in reply to Tom in Central Pa., 02-17-2006 17:39:23
Thanks Tom!
Thanks again!
