Tractor Talk Discussion Forum
plate compactor
Jim Williamson
02-16-2006 22:36:46
Hi all, This is a bit off dep't but I have a Case vibromax plate compactor and it had a Kohler engine 25 years ago which I changde to Honda about 20 yr ago. It has 4 rubber vibration dampers shaped like an hour glass. They have a German type name on them. Can anyone tell me where I can get replacements? Any ideas would be appreciated. Thanks JW
Vern-MI
02-17-2006 04:36:51
 Re: plate compactor in reply to Jim Williamson, 02-16-2006 22:36:46
It probably is a sandwhich mount isolator. Try your local bearing supplier or go to Lord at the following location:
Vern-MI
02-17-2006 04:42:34
 Re: plate compactor in reply to Vern-MI, 02-17-2006 04:36:51
Here is another place in Georgia:
T_Bone
02-18-2006 05:34:03
 Re: plate compactor in reply to Vern-MI, 02-17-2006 04:42:34
Hi JW,
You might also look at refrigeration compressor isolaters as there shaped simular in the 25ton to 50ton class of compressors. About $20 for a set of four. Any refrigeration supply house would have them.
Transmission mounts would also be simular at NAPA.
T_Bone
