Tractor Talk Discussion Forum
Identification of Tractor
Jeff Higgins
02-16-2006 18:45:44
I am having trouble getting parts for my tractor, I went to the tractor place and they say they are not pulling up the same numbers for my tractor.. Could someone please help me identify my tractor.. I believe it is a 4000.. All the numbers I have found are:
C5NN 6015
PG178962F216
Thanks for all your help!!
colekicker
02-17-2006 10:06:11
 Re: Identification of Tractor in reply to Jeff Higgins, 02-16-2006 18:45:44
There should be a little aluminum plate underneath the hood that has a series of numbers on it to identify the production. Should start with a number then a letter. If you search on the ford portion of this site I have posted a detailed way to read this. If the aluminum plate is not there, I think there is a serial number stamped into the tractor on the left side at the top of the bell housing, but I can"t remember if that is right or not. If so, it is right above where the couple mounting holes are at.
Hugh MacKay
02-17-2006 02:42:17
Jeff: Which make, just for starters Deere and Ford have each used the model number 4000?
Jeff Higgins
02-17-2006 05:01:27
 Re: Identification of Tractor in reply to Hugh MacKay, 02-17-2006 02:42:17
Sorry, but it is a Ford.
Hugh MacKay
02-17-2006 06:27:07
 Re: Identification of Tractor in reply to Jeff Higgins, 02-17-2006 05:01:27
Jeff: I doubt if I'll be able to help you much. I picked up on that as years ago I had two neighbors, one on each side of me. One guy had a Ford 4000 and the other guy had a Deere 4000. I farmed with Farmalls myself. All good tractors in my opioion.
I noticed you more so because of you name, Higgins, my home town was 40% Higgins, 50 years ago. They settled there in the 1700s. Since that time they've spread out across this continent. This was in Nova Scotia and there was even a school section in my area called Higginsville. The only other place I've seen that is a place called Higginsville MO. Some of those Higgins' in my home town are quite heavy into old iron as well. I supose you could be one of them, never thought of that. If not, and you wish to know more send me an email.
souNdguy
02-16-2006 20:52:11
Look int he following places.. under hood for vehicle id plate, on the hyd top cover for production code, right side above starter for tractor model no, production code, and serial number.
Soundguy
