Tractor Talk Discussion Forum
Help on PTO Pump
Keith-OR
02-15-2006 14:48:39
Need info on this pump. Anyone know what brand it is? I blew ouside shaft seal no numbers on seal...Help!!! Thanks
Model # Hi25A Has casting IB524 on outside and IB523 on side facing tractor
Keith & Shawn
third party image
Link
Leland
02-15-2006 21:29:03
 Re: Help on PTO Pump in reply to Keith-OR, 02-15-2006 14:48:39
Find Allan in NE he has the answer he had a picture of one earlyer
Keith-OR
02-15-2006 17:34:40
Took the old seal to NAPA they could not find one tha would work. I had the output shaft OD and measured the inside of housing and old seal with me. Guess I will try local hydraulic repair shop tomorrow.
Hey Old, bite your tongue on putting on front pump. LOL
Thanks guys!!!
Keith & Shawn
old
02-16-2006 10:10:08
 Re: Help on PTO Pump in reply to Keith-OR, 02-15-2006 17:34:40
Well a front pump or you could fix the on board pump and use it.
souNdguy
02-15-2006 16:54:04
I'm with bob... assuming there is no internal failure, and good hydro shop should be able to match a 'will-fit' seal based on id, od, and thickness.
Soundguy
Bob
02-15-2006 15:59:12
I can't identify that pump, offhand, although I'm sure I should reconize it.
No problem, though. Any REAL auto parts store, or "bearings and drives"-type place can fix you up with a seal by internal and external dimensions.
However, there MAY be a seal farther in that has failed. That is the case with SOME pumps.
old
02-15-2006 15:34:57
Looks a lot like a prince brand pump, just guessing but that is what the ones I have seen looked like. You may yet end up putting a front mount pump on that S77
