Tractor Talk Discussion Forum
New Idea 506 loader
Jonney M
02-15-2006 10:26:25
Hello,
I am looking for info on a New Ideal 506 loader. It came off a 730 case tractor. I would like to know how well It would fit a 656 Farmall.
Does any one have any info on this loader????
Thanks
MNredfarmer
02-15-2006 13:05:15
 Re: New Idea 506 loader in reply to Jonney M, 02-15-2006 10:26:25
I cant remember which style the 506 is but if it's the style of brackets that hook up to the rear axle then it will fit. they are pretty universal. If it is the stlye that mounts in the middle of the tractor you have might have a differant width between the Case and the IH and have to fabricate something.
RustyFarmall
02-15-2006 10:41:48
Don't know anything about that loader, but if it will fit a 730 Case, it should fit a 656 Farmall. Those two tractors are very similar in size and dimensions. I doubt very much if it will be as easy as removing it from the case and installing on the Farmall. You will most likely need to fabricate some brackets, or modify the brackets that are with the loader. If you are lucky you may be able to locate some brackets made specifically for mounting that loader on a 656.
