Tractor Talk Discussion Forum
Forrd 961 power steering pump vs. Ford truck pump
jjp
02-14-2006 06:48:43
I am having difficulty locating a power steering pump for my Ford 961 Row Crop tractor. This is the "new style" roller vane type pump.
Someone told me this was the same pump used in the early 1960"s Ford 1/2 ton trucks. Does anyone know if this is correct?
Thanks!
txgrn
02-14-2006 08:10:27
 Re: Forrd 961 power steering pump vs. Ford truck p in reply to jjp, 02-14-2006 06:48:43
I had a early '60's 4 cyl 4000 that had no pump. I thought I was clever and went to a junk yard and obtained an automotive pump from a Ford Pinto.
Got it working, but after I did I noticed that you had to turn the wheel slowly to give the pump time to move 2 cylinders.....whereas the Pinto only had 1; and the tractor ran at half the speed of the Pinto. So if you after market, watch your volume.
I could have put a smaller pulley on it to get it to run faster, but that was more than I wanted to do being it was a power steering pump and not a standard pulley setup..... never had a pulley off and didn't know how to nor what I'd be getting into. I know, I could look in a motors manual to figure it out but I didn't have the tractor much longer.
Mark
