Tractor Talk Discussion Forum
8240 ford tractor
casey cordova
02-12-2006 20:08:18
my ford 8240 2wd tractor keeps poping out of high range.if you ride the clutch it will stay ingaged but if you let it out all the way it just stops. anyone have any ideas, or any trouble shooting tech. thanks
RodInNS
02-13-2006 10:36:04
 Re: 8240 ford tractor in reply to casey cordova, 02-12-2006 20:08:18
Is this a 12x12 transmission? If so, then check the linkages for play, slop, pins falling out, etc. Find the appropriate lever on the side of the transmission and see if you can push it into gear manually as you have a helper move the shift lever. Those linkages were known to be sloppy. I have one that locks in low range if I'm not careful about how I shift. Just a plain stupid design..... Otherwise, I would suspect you have an internal problem, likely a syncronizer. HTH.
Rod
