Tractor Talk Discussion Forum
2010 Hydraulic System
jimjo2
02-12-2006 12:16:06
I have a 2010, no serial number, so I have no idea what year. It has a bucket loader on it, JD36, with manual trip and I would like to install additional hydraulics for a hydraulic dump. Does anyone know if this is possible? I have looked in the service manual for a live pressure line to run out to a control valve but I haven't seen any way to do it. Am I overlooking someting somewhere? Any and all help would be appreciated. I know this tractor has some controversy with some guys but it really is a decent tractor for what I need it for.
DLM
02-12-2006 14:28:47
 Re: 2010 Hydraulic System in reply to jimjo2, 02-12-2006 12:16:06
Does this have a two spool valve if it does there is no problem if it is a single spool then look and see if it has a power beyond plug then you could add another valve but if no power beyond then i would sugest installing a two spool valve. Surplus Center has some reasonable price valves.Don
jimjo2
02-13-2006 17:38:48
 Re: 2010 Hydraulic System in reply to DLM, 02-12-2006 14:28:47
All the tractor has is the original single hydraulic outlet at the rear. My problem is where to install an additional live system.
JD9295
02-12-2006 13:46:01
HEY JIMJO, try plumbing it with a joystick, one inlet and then 2 out to the cylinders(bucket and lift)
jimjo2
02-13-2006 17:40:35
 Re: 2010 Hydraulic System in reply to JD9295, 02-12-2006 13:46:01
This is one possibility that I have thought of but getting the live power to it is the problem.
msb
02-12-2006 13:38:54
About all the 2010s locally had 2 spool Gresen valves on them, but I can't remember how we plumbed them.
jimjo2
02-13-2006 17:42:43
 Re: 2010 Hydraulic System in reply to msb, 02-12-2006 13:38:54
I am quite certain this only has a single spool valve installed.
