Tractor Talk Discussion Forum
Painting rims
jackt
02-10-2006 09:53:20
Got some used rims to replace the rusted out rears on my WD45. These have some rust and pitting, but not great gaps with the innertubes poking through like the old ones. After I sand blast them, what"s the best coating/paint to use? Originally they were cad plated but that"s not a do it yourself job. I"ve tried cold galvanizing paint before but that seems to scrape off pretty easily. Should I just use aluminum paint?
Thanks
Greasey Hand
02-11-2006 08:56:53
 Re: Painting rims in reply to jackt, 02-10-2006 09:53:20
Use DP 40 & DP 401 This is an epoxie Primer made by Ditzler, This is the primer, Sand blast the rims good then clean them good, I use an acid.
Before the primer is dry (Still wet in places) put the finish color on, Have this redy to go, Use an epoxy wet look paint in the same brand for a good hard finish, Follow the instructions & don't forget to clean your paint gun out as soon as your done, Reel good! This will last for years & years if you do it right.
Randy_NE
02-10-2006 10:26:27
Some discussion just the other day.
